doitright
change indivual wall heights
I am working on a commercial 1 storey interior tenant fit out project and using a combination of CAD sections and CA floor plan elevation shots to create final interior elevations. I do not require a roof or ceiling.
I can not find a way to change the height of one wall without other walls also changing height.
Thanks for any help.
You can always just drag it down in section-elevation view. You might be able to use the new shelf ceiling tool depending on if you need a lowered ceiling or not.
When you click on the wall in a 3D view, by default the ROOM is selected first.  Either hit tab to select the wall or go into preferences and change the behaviour here...
Another option would be to use a "half wall" but then set it to whatever height you want.
    28293
    Vevalee
    Vevalee
