How do I fix this?
MAINEWOOD59
Select the Room and open the Room Specification dbx. Select the Materials tab; notice the Component>Rooms>Walls reads "No Change." This indicates that some of the walls are using different materials.
With Walls selected, click Select Material, and check the Use Default Material checkbox down in the lower left (this follows Solver's guidance).
This will fix your walls, though you still need to deal with the end wall, which is currently defined as an exterior wall with the siding material.
Expand
Great Post
