LarsCD Posted April 5, 2017 Share Posted April 5, 2017 I am trying to create a box window similar to the attached picture. I am trying to have the windows join at the corners without a wall, just a post. I can get it to work on one side, however when I do the same thing to the other side, it removes it from the first side. I have attached pictured of what this looks like. Does anyone know how to fix this? I am using Chief X9. Link to comment Share on other sites More sharing options...
DougMaddox Posted April 5, 2017 Share Posted April 5, 2017 Lars I placed a polyline solid post at each corner the height of the window and slightly larger than the wall thickness. Works for my purposes. Doug Link to comment Share on other sites More sharing options...
CJSpud Posted April 5, 2017 Share Posted April 5, 2017 I can get it close to looking right but it takes a lot of fiddling around the way I am doing (massive amounts of raw force applied in the needed directions). Good luck. Link to comment Share on other sites More sharing options...
MarkMc Posted April 6, 2017 Share Posted April 6, 2017 Use a cabinet?or turn one into a window symbol (get tricky as shown) Link to comment Share on other sites More sharing options...
dshall Posted April 6, 2017 Share Posted April 6, 2017 19 hours ago, LarsCD said: I am trying to create a box window similar to the attached picture. I am trying to have the windows join at the corners without a wall, just a post. I can get it to work on one side, however when I do the same thing to the other side, it removes it from the first side. I have attached pictured of what this looks like. Does anyone know how to fix this? I am using Chief X9. I remember seeing where one side gets fixed and then the other side is screwed up. I bet if you posted your plan, at least the wall with the window, I bet someone if not myself will give it a try. I bet I could do it using thin walls defining a bay window with a raised floor.... Link to comment Share on other sites More sharing options...
MarkMc Posted April 6, 2017 Share Posted April 6, 2017 12 minutes ago, dshall said: I bet I could do it using thin walls defining a bay window with a raised floor.... I tried that too-gets messier than making a symbol from a cabinet but you do have a bit more control. Link to comment Share on other sites More sharing options...
CJSpud Posted April 6, 2017 Share Posted April 6, 2017 Mark: I need to give that method a try. Amazing how some of the tools can be put to use. Link to comment Share on other sites More sharing options...
MarkMc Posted April 6, 2017 Share Posted April 6, 2017 Curt-here's what I played with-added the second cabinet (middle) after I created the first symbol, third is a cabinet inside a cabinet to increase wall thicknes. None completely done. Not entirely working as a window yet but maybe could be. Link to comment Share on other sites More sharing options...
