capitaldesigns Posted February 16, 2017 Share Posted February 16, 2017 I am doing a small addition/remodel. We are enlarging the family room. One of the new walls of the addition will connect an existing 45 degree wall corner. When I connect the new wall to the existing 45 degree wall corner the existing walls disconnect from each other and looks like they trying to merge with the new wall. How do I keep the existing wall corner to remain attached to each other ? I have attached the plan so you can see what I am talking about. One more question. How do I wrap a beam with 1/2" gyp. bd. ? Thanks, Mike 2017-02-X9_Design_1.plan Link to comment Share on other sites More sharing options...
capitaldesigns Posted February 16, 2017 Author Share Posted February 16, 2017 Thanks Eric, What do you mean, Through Wall at End ? How do I do that ? Thanks, Mike Link to comment Share on other sites More sharing options...
Chopsaw Posted February 16, 2017 Share Posted February 16, 2017 Link to comment Share on other sites More sharing options...
capitaldesigns Posted February 16, 2017 Author Share Posted February 16, 2017 Eric, I found the through wall at end. That fixed it. Thanks Again, Mike Link to comment Share on other sites More sharing options...
DRAWZILLA Posted February 16, 2017 Share Posted February 16, 2017 You can also use the "Edit Wall intersection " tool on the edit toolbar after you select a wall Link to comment Share on other sites More sharing options...
