mslewis620 Posted February 11, 2017 Share Posted February 11, 2017 On my drawing sheet a purple box keeps showing up that when I try to save a plan as a pdf it cuts off the page at the bottom of the purple box. I've looked at everything I can think of to get rid of it. I can't select it to delete it. Any suggestions? Link to comment Share on other sites More sharing options...
DRAWZILLA Posted February 11, 2017 Share Posted February 11, 2017 Those are your crosshairs just move them out of the scene or turn them off. On second thought, its you paper size margins. Link to comment Share on other sites More sharing options...
RL-inc Posted February 11, 2017 Share Posted February 11, 2017 Perry is right on the paper margins- Go into drawing sheet set up and adjust. Link to comment Share on other sites More sharing options...
mslewis620 Posted February 12, 2017 Author Share Posted February 12, 2017 It's definitely not the crosshairs - maybe the image doesn't properly reflect the situation. I've adjusted the margins to no avail. It's showing up as a big purple box outline that prints about 2/3 of the screen. Now I have a bigger issue. Frequently go back and forth between work and home without issue until today. X8 won't open no matter what I do. Deactivated my license at work and X8 won't open at home. Lots of work to do so may have to go back to office tonight. Bummer. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 12, 2017 Share Posted February 12, 2017 That has to be your drawing margins. Print>Drawing Sheet Setup>Drawing Margins...adjust your bottom margin to match the side and top margins... Link to comment Share on other sites More sharing options...
