Soffits Under Roof Planes
RL-inc
I am having trouble with soffits and roof overhangs.
most of the time we build with finished materials on top of the rafters or trusses in the eave and up the gable rakes.
as you can see in the attached snip the soffit material is below the gable fascia and hanging below the flat soffit material in the covered porch.
if I uncheck soffits in the options dbx it eliminates the soffit material in the rake but still shows protruding down below the flat soffit in the covered porck.
any suggestions on what I may be missing.
That is caused (in your posted image) by improperly connected roof planes, fixt the mating edges of those to roof plans and the soffit problem will dissapear with it. (join Roofs tool after you straighten out the gable plane by getting rid of the unnecessary line break in it).
