howardr 0 Posted January 26, 2017 I have be experiencing a number of semi crashes of X9 and wonder if anyone else is seeing it as well. I call them semi crashes as the program does not actually crash but I am prompted to open save or cancel at semi random times and in all cases this happens when I am switching from a camera view back to plan view. When it does this the camera view is closed without my intervention regardless if I hit cancel. If I hit save it closes my open plan and leaves me at the file menu. It does not appear that there is any consistency in these events as repeating the actions I took in a camera view just after a crash has occurred do not result in another event. I tried this on an existing plan and on a new plan and get the same event with XP being on all the default settings/values. Share this post Link to post Share on other sites
DRAWZILLA 780 Posted January 26, 2017 I don't think X9 is approved for XP. X9 only works in 64 bit systems now. Share this post Link to post Share on other sites
howardr 0 Posted January 26, 2017 Title changed, I was referring to X9 lol. Darn fat fingers. Share this post Link to post Share on other sites
Kiwideziner 37 Posted January 26, 2017 my guess is you are using an old system which is being taxed too hard by X9, possibly video card? compare your system to those in our signatures. however just a guess. Share this post Link to post Share on other sites
howardr 0 Posted January 27, 2017 System should not be an issue I7 although a few years old and a new 1080GTX should be more than capable of running it. Besides the way the issue presents itself by asking if I want to open save or cancel lends to a different symptom. Share this post Link to post Share on other sites
DRAWZILLA 780 Posted January 27, 2017 I am asking if you have XP or not. Chief X9 only runs on 64 bit systems now- no 32 bit systems Share this post Link to post Share on other sites
howardr 0 Posted January 27, 2017 I am not running Windows XP, its Windows 10. Share this post Link to post Share on other sites
BrownTiger 91 Posted January 28, 2017 First have you experienced same crashes with x8? Verify Windows, I would run repairs 1) sfc /ScanNow 2) DISM /Online /Cleanup-Image /RestoreHealth /Source:repairSource\install.wim I would also check the video drivers... If you have accelerator card and not Intel built-in a) Make sure that the drivers are updated b ) You are set to use accelerated hardware Share this post Link to post Share on other sites
howardr 0 Posted February 1, 2017 Okay I do not experience the same issues in X8 and I have verified windows to be functional as no errors were encountered. There must be something on my end that's not correct in order to cause this given that none of you have seen it so I will keep digging here. Thanks for your efforts. Share this post Link to post Share on other sites
