COLONIAL-CHIEF Posted January 25, 2017 Share Posted January 25, 2017 When I select the automatic dimension tool it will only dimension my garage portion and not the main house floor plan (only on the first floor, second floor works fine). This is house we designed previously for a different lot and when we decided to use it for another lot I had to rotate the plan, which might have something to do with it. FYI I'm using X7. Walk Residence.plan Link to comment Share on other sites More sharing options...
lbuttery Posted January 25, 2017 Share Posted January 25, 2017 just guessing check your wall connections do you have room definitions for every room ? Lew Link to comment Share on other sites More sharing options...
javatom Posted January 25, 2017 Share Posted January 25, 2017 Make sure the automatic dimension layer is on. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted January 26, 2017 Share Posted January 26, 2017 8 hours ago, COLONIAL-CHIEF said: When I select the automatic dimension tool it will only dimension my garage portion and not the main house floor plan (only on the first floor, second floor works fine). This is house we designed previously for a different lot and when we decided to use it for another lot I had to rotate the plan, which might have something to do with it. FYI I'm using X7. Walk Residence.plan I'm not sure what the problem is. I opened in X7, hit Auto Exterior Dimensions and this is what I got... Seems to be working just fine to me. Dunno what ta tell ya. 1 Link to comment Share on other sites More sharing options...
COLONIAL-CHIEF Posted January 26, 2017 Author Share Posted January 26, 2017 Yeah Alaskan_Son you must have the "Midas Touch", I'm not sure what is going on still can't get it to show. Works fine on the garage portion of first floor, the entire second floor and entire foundation plan. Auto dim layer is on and all my walls are connected. STUMPED! Link to comment Share on other sites More sharing options...
