Pony Wall Alignment
ACADuser
See attached screen grabs. I wanted the glass upper portion of the pony wall centered in the wall but when I do that the floor below the wall does not build properly. Is there a better way to do this?  X9 Beta and the room is a Balcony which controls the wall height with the Ceiling height setting.
Alan, give DScott Halls parapet build video on You tube a try?  I think there's a possibility you could use this as a work around if the GURU's on here don't have a better (correct or easier) way to do it. Not sure of course.
Hey Alan,
There are a good handful of ways to accomplish what you're trying to do, but here's one of the most straightforward in case you haven't considered it...
Simply set that wall to be a railing and give it a very tall and narrow glass top rail.  Just a thought.
