RGWhite Posted December 17, 2016 Share Posted December 17, 2016 (edited) I find this interesting and fustrating. I need to submit the manufacturer's installation details with the plans. So I down load the sheets as PDF's and import them into the layout. If I should change anything on the PDF and save it as a PDF, CA will still import the old PDF even though I changed the info on the PDF. In Florida we must fill out the products we will use for the exterior and they give you a sheet that must be submitted with the plans. My client changed his mind and I made the product change and saved it. I went to reimport it and CA still uses the old file that does not exist. The only way I could correct this is by giving the new PDF a new name altogether. Am I doing something wrong or is this a bug? Thanks for any help Edited December 17, 2016 by RGWhite missspelled word Link to comment Share on other sites More sharing options...
BrownTiger Posted December 17, 2016 Share Posted December 17, 2016 How about save new PDF under a different name. Delete the original. When opening layout Chief will offer to replace the missing file. Select a new Pdf. Link to comment Share on other sites More sharing options...
RGWhite Posted December 17, 2016 Author Share Posted December 17, 2016 Yes that is what I did. My question still stands: Why won't CA recognize the changed document? Link to comment Share on other sites More sharing options...
glennw Posted December 17, 2016 Share Posted December 17, 2016 I am not sure if it makes any difference, but do you have Save In Plan checked in the PDF Specification dbx? Link to comment Share on other sites More sharing options...
RGWhite Posted December 17, 2016 Author Share Posted December 17, 2016 I checked the (save in plan) box and unchecked the box. It made no difference. Link to comment Share on other sites More sharing options...
Chopsaw Posted December 18, 2016 Share Posted December 18, 2016 I think once you check the save in plan box then unchecking it takes no effect until you close and reopen the plan or possibly even do a save as. Can't remember for sure. Link to comment Share on other sites More sharing options...
BrownTiger Posted December 18, 2016 Share Posted December 18, 2016 You are 100% right. Chief caches PDF somewhere, unless name of the file is changed it doesn't appear to read it again. The checkbox "save in layout" does not appears to make any difference. Also it explains how can ChiefArchitect open layout/plan files with multiple PDFs attachments so quickly. Sooo You have to change the file name. Link to comment Share on other sites More sharing options...
RGWhite Posted December 18, 2016 Author Share Posted December 18, 2016 Thanks everyone. I wish the instruction manual had informed me of this. It would seem more intutive for the progam to simply overwrite the updated doc without changing to a new file. 1 Link to comment Share on other sites More sharing options...
