johnny Posted December 16, 2016 Share Posted December 16, 2016 Can I adjust the text formatting in Window/Door schedules? Say I want to place a space in the reporting for header sizes so that it doesn't look like: 5 1/2X7 1/2X52 1/2", but rather 5 1/2 X 7 1/2 X 52 1/2". Also, if I set a Glu-lam the sizes only show as nominal and around here we typically show actual sizes. I see I can set to "engineered lumber" to get actual size, but is there a way to get Glu-Lam to show actual? Link to comment Share on other sites More sharing options...
BrownTiger Posted December 16, 2016 Share Posted December 16, 2016 No chance, the only thing adjustable (by macros) on the scheduler is a label. Like you stated, use engineered lumber to get actual size. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted December 16, 2016 Share Posted December 16, 2016 BT isn't correct. Sub Components can be assigned macros that do this kind of formatting. Actually, the following fields in the Component's dbx can also have macros inserted in them: component_code comments description manufacturer Ther might be a few more. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted December 16, 2016 Share Posted December 16, 2016 Yep. Definitely doable. Would require some custom macros to set up though and some thought given as to the best way to make it work for your particular desired output. Quick answer though is that there isn't anything you can quickly and easily change without using Ruby and text macros. Link to comment Share on other sites More sharing options...
BrownTiger Posted December 17, 2016 Share Posted December 17, 2016 Even if you assign macro to "W1" component field like comment, header and width data are not available. If I understand correctly what Joe is suggesting is to capture data in the label (store on global) and display in the component. Ugh Link to comment Share on other sites More sharing options...
Joe_Carrick Posted December 17, 2016 Share Posted December 17, 2016 No, that's not what I was suggesting. It's much easier than that. Also, I don't agree with Michael that it would require custom user macros. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted December 17, 2016 Share Posted December 17, 2016 4 minutes ago, Joe_Carrick said: No, that's not what I was suggesting. It's much easier than that. Also, I don't agree with Michael that it would require custom user macros. If you're referring to manually entering "static" data into those fields then yes...of course we can do that. I guess I was assuming automation was the desired end product and that Johnny would have already realized he can enter data manually. I guess I could be assuming incorrectly though. There are only 3 ways I know of to get window header information into the schedule and PLEASE correct me if you think I'm wrong... 1. Enter "dumb" data manually for every window using one of the aforementioned fields or by adding a sub component. 2. Use the provided header column in the schedule. 3. Fairly complex ustom user macros. If you know of a 4th method I'd be very interested to hear what it is. Link to comment Share on other sites More sharing options...
