olyconstruction 1 Posted December 6, 2016 Hi Chiefs, I am using this arched doorway as you can see in the attached image. You can also see that the door is sort of carving out a rectangle above the arch. Has anyone seen this before / know whats going on here? Thank you! AB Share this post Link to post Share on other sites
Rosco2017 48 Posted December 7, 2016 Wow. Never seen that one before. Can you post the plan? I'll take a look at it. Share this post Link to post Share on other sites
DRAWZILLA 784 Posted December 7, 2016 Have you tried making that wall" balloon through ceiling". Or the wall abv. go through floor Share this post Link to post Share on other sites
olyconstruction 1 Posted December 8, 2016 Here is a zip of the file Rosco. Drawzilla: I tried both those things after your suggestion but no results. Thanks for the help guys! JAMES_-PROPOSED_2_-_11-9-16.zip Share this post Link to post Share on other sites
Kenoeightspot 80 Posted December 8, 2016 Move the stair away from the door opening. The door will appear correct. 1 Share this post Link to post Share on other sites
olyconstruction 1 Posted December 8, 2016 Keno 8 for the win!! I did not know that stairs cut walls like that. Hmm Share this post Link to post Share on other sites
