olyconstruction Posted November 1, 2016 Share Posted November 1, 2016 Hi Chiefs, I am trying to make this T-111 material, just using the vertical siding texture with the color green I want. I am really struggling with setting up the surface pattern. How do I set it to look like vertical stripes? Thank you for your help! AB Link to comment Share on other sites More sharing options...
Solution mattyt12 Posted November 1, 2016 Solution Share Posted November 1, 2016 change the material type from area to strip on the pattern tab, you can control the angle you want here but to adjust the spacing you go to the general tab 1 Link to comment Share on other sites More sharing options...
Chopsaw Posted November 1, 2016 Share Posted November 1, 2016 I Assume that you mean the vector display properties. 1 Link to comment Share on other sites More sharing options...
olyconstruction Posted November 2, 2016 Author Share Posted November 2, 2016 Thank you guys! Yeah strip pattern is what I needed, I guess the spacing is too large at the default to see what I was going. Changed it to 6" like in chopsaws example and now its all awesome! Link to comment Share on other sites More sharing options...
DRAWZILLA Posted November 2, 2016 Share Posted November 2, 2016 Just pick one from the James Hardie catalog and change the color. If the spacing isn't right change the texture size and the pattern size. Link to comment Share on other sites More sharing options...
