Roof Eave (soffit) lining height
RobWhite
Go to solution Solved by dshall,
How do I raise the eave sheet.
I thought this happened automatically. When I reduce the roof overhang from 600 to 550 the eave sheet is staying at the same level. How do I raise the eave sheet or set it automatically to adjust relevative to the overhang.
See the attached
I use chief X8
Roof
Roof Eave.pdf
  • Solution
See the attached
I use chief X8
Roof
Attach the plan.....  but the quick answer is the soffit elevation is a function of the SUBFASCIA.
If you post a plan,  I bet you will get more answers.  You have been around awhile,  you know to post the plan for the best answers.
Rob,
Try:
Build... Roof...Edit All Roof Planes...Structure panel...Roof Size...reduce the size of the Eave Sub Fascia.
If you build the roof framing and display the Framing, Roof Rafters layer in a section view, you will see the sub fascia and how it effects the eaves height.
