Don_Straub_Const Posted August 24, 2016 Share Posted August 24, 2016 I am drawing an outside stairway to the upstairs for an entrance of a duplex. How can I change the decking to be concrete? i can edit the beams and posts to be iron and the stairs and the railings but the decking I have not figured out how to edit. Link to comment Share on other sites More sharing options...
Chopsaw Posted August 24, 2016 Share Posted August 24, 2016 Change your room definition from Deck to Porch. That should take care of it by default. Link to comment Share on other sites More sharing options...
Don_Straub_Const Posted August 24, 2016 Author Share Posted August 24, 2016 Thanks Chopsaw, I tried the solution two things happened all the framing for the deck went away the posts and beams. The second thing was the roof line configured to cover the now porch. any other ideas? Link to comment Share on other sites More sharing options...
ShaneK Posted August 24, 2016 Share Posted August 24, 2016 Open porch room dbx/structure/uncheck "roof over this room" and rebuild roof planes. Link to comment Share on other sites More sharing options...
Chopsaw Posted August 24, 2016 Share Posted August 24, 2016 Hopefully Shane's suggestion will fix the roof for you, and the deck framing is what you wanted to replace with concrete? Not to sure why the posts and beams were affected. Could you post some screen shots or maybe the plan file? Link to comment Share on other sites More sharing options...
rlackore Posted August 24, 2016 Share Posted August 24, 2016 Don't use a room or deck. Create a landing, manually add the posts, then change the landing materials. Link to comment Share on other sites More sharing options...
Don_Straub_Const Posted August 24, 2016 Author Share Posted August 24, 2016 What I wanted to accomplish was to replace the decking with concrete and assign the post and beams to be steel, I had a issue with the joisting but made it 3/4" plywood and changed the planking to 0 gap and a width wider than the landing and assigned concrete to it. What I wanted to end up with was a steel beam and post framing supporting a 4" to 6" concrete deck. Here is the plan at ground zero again. stairs dup.pdfmeeting 1.plan Link to comment Share on other sites More sharing options...
