Charles Posted August 22, 2016 Share Posted August 22, 2016 How would you do a shutter with an angled top like the one in the photo? Thanks in advance. Link to comment Share on other sites More sharing options...
Kiwideziner Posted August 22, 2016 Share Posted August 22, 2016 use match roof in window dbx Link to comment Share on other sites More sharing options...
Rich_Winsor Posted August 22, 2016 Share Posted August 22, 2016 Whoever hung those "shutters" apparently was unclear on the concept of what a shutter is. Granted they are obviously intended to be purely ornamental as shutting them would not cover the window. I don't think you can get that arrangement using Chief's Window Tools. Chief want's to have shutters that will cover the window area when shut (and rightly so). 2 Link to comment Share on other sites More sharing options...
Chopsaw Posted August 22, 2016 Share Posted August 22, 2016 If it is and absolute necessity use all the tools that Rich used to create the size of shutter you need and then convert to symbol and use in your plan. Edit symbol for exact replica using polyline solid components paint and recreate symbol. Not easy but can be done if necessary and someone is paying. Or maybe check the 3D warehouse first before wasting a whole lot of time. Link to comment Share on other sites More sharing options...
Charles Posted August 23, 2016 Author Share Posted August 23, 2016 Thanks, everyone..... that's what I figured, but wanted to be sure there wasn't a trick that I missed! Link to comment Share on other sites More sharing options...
