dshall Posted August 21, 2016 Share Posted August 21, 2016 Hi please open plan, do a floor overview, Can you flip corner cab door direction? If so, how did you do it? I can tell you, flip cabinet and then you need to rotate in plan.... is this weird? Why can't we open dvx and change swing side? BBB FLIP DOOR TO OPEN RIGHT NOT LEFT.plan Link to comment Share on other sites More sharing options...
DRAWZILLA Posted August 21, 2016 Share Posted August 21, 2016 I know this is too simple, but I just copy/ reflect about. Not sure I understanding what you want b/c I know you know this. I did not do the floor overview. Link to comment Share on other sites More sharing options...
dshall Posted August 21, 2016 Author Share Posted August 21, 2016 I know this is too simple, but I just copy/ reflect about. Not sure I understanding what you want b/c I know you know this. I did not do the floor overview. That is the answer... of course you now to to rotate the new cabinet 180 degrees in plan view....... the point is with most cabinets you can change a door from a right cabinet door to a left cabinet door. With the corner cabinet, you can not do that........ seems like a very small loss of function. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted August 21, 2016 Share Posted August 21, 2016 I didn't know that ,thanks Link to comment Share on other sites More sharing options...
glennw Posted August 21, 2016 Share Posted August 21, 2016 Scott, You are correct, it is too simple! Open the dbx. Front/Sides/Back panel. In the preview pane select the door by it's hinged or right hand side, NOT the handle side. You can't select the door by selecting the handle or left side. Make sure "2 Door - Auto Right" is selected. Change Item Type to "Door - Auto Left". http://screencast.com/t/C8l7Pwvc9hI Link to comment Share on other sites More sharing options...
dshall Posted August 22, 2016 Author Share Posted August 22, 2016 Scott, You are correct, it is too simple! Open the dbx. Front/Sides/Back panel. In the preview pane select the door by it's hinged or right hand side, NOT the handle side. You can't select the door by selecting the handle or left side. Make sure "2 Door - Auto Right" is selected. Change Item Type to "Door - Auto Left". http://screencast.com/t/C8l7Pwvc9hI Thx, I will give it a try. Link to comment Share on other sites More sharing options...
rosietesmen Posted August 22, 2016 Share Posted August 22, 2016 I just looked at a ton of photos on Houzz and from what I saw there, I would say yes. Much easier access with the hinge on the other side as well. Link to comment Share on other sites More sharing options...
