Darrell_Playle Posted August 15, 2016 Share Posted August 15, 2016 Hi all,when I send an elevation to layout selecting plot lines and colour fill options I am losing colour fill. Sometimes it will work however if I update the view at any point it will partially lose fill and remaining colours is faint whilst some portions will remain as they should. I have tried everything I can think off to rectify including deleting the camera and starting again, shutting the program down and re opening etc. If I undo commands it will return to the full colour only to return to the problem once I update the view. Any help greatly appreciated as its doing my head in Link to comment Share on other sites More sharing options...
Chopsaw Posted August 15, 2016 Share Posted August 15, 2016 Some of those issues resolve themselves when you print. Try printing to PDF to check. If not post some screen shots and we will all try to help. Or call tech support in the morning if you don't get a response here. Based on the issue I assume X8 but please post your version. Link to comment Share on other sites More sharing options...
Darrell_Playle Posted August 15, 2016 Author Share Posted August 15, 2016 Thanks Chopsaw, yes it is X8 that I am using and the problem still existed when printing. I just had some success by opening the layout box then changing from live view to plot lines and I have managed to make it work for the time being. I have been using X8 since it was released and this problem didn't exist until recently and it is getting worse with each new plan 1 Link to comment Share on other sites More sharing options...
Chopsaw Posted August 15, 2016 Share Posted August 15, 2016 There are always variable issues with resolution quality in live views but apparently it is supposed to work that way to save memory and they are supposed to print properly at full resolution. You may want to send your plan file in to tech so they can check it out for you. Link to comment Share on other sites More sharing options...
Francois Posted August 15, 2016 Share Posted August 15, 2016 Print to "Chief Architect Save As PDF", not any other PDF. You can select it from the print DBX Link to comment Share on other sites More sharing options...
Darrell_Playle Posted August 17, 2016 Author Share Posted August 17, 2016 printing to a chief PDF doesn't work, wont print correctly in any format and nothing will correct it for long so I have sent the file to tech support, they say they haven't heard of this issue before either. thanks for your help guys Link to comment Share on other sites More sharing options...
ShaneK Posted August 18, 2016 Share Posted August 18, 2016 Post the plan. It will be resolved and fixed with file uploaded for you to review and find out what's going on. Link to comment Share on other sites More sharing options...
Darrell_Playle Posted August 18, 2016 Author Share Posted August 18, 2016 already sent to the tech guys ShaneK just waiting on their response 1 Link to comment Share on other sites More sharing options...
Solution Darrell_Playle Posted August 30, 2016 Author Solution Share Posted August 30, 2016 all sorted...........turned out with X8 your graphics card driver must be newer than 2013..........mine wasn't and now is so problem is resolved 1 Link to comment Share on other sites More sharing options...
