ACADuser Posted July 25, 2016 Share Posted July 25, 2016 See attached plan level 4 I need to put a DECK on top of the Roof. The Roof will be pitched 1/4 per foot toward the rear. The deck will sit on the roof & step down as the roof tapers. I was going to model this but it appears I may not be able to. Any thoughts? MacDill RH-Unit A.zipFetching info... Link to comment Share on other sites More sharing options...
DavidJPotter Posted July 25, 2016 Share Posted July 25, 2016 The deck must be draw in a hole in the roof or an area where the roof surrounds but does not intrude on the deck space. If the deck is to be stepped then you divide the deck space so by its dialogs it can be controlled as to its floor height. DJP Link to comment Share on other sites More sharing options...
ACADuser Posted July 26, 2016 Author Share Posted July 26, 2016 Thanks David Link to comment Share on other sites More sharing options...
ACADuser Posted July 26, 2016 Author Share Posted July 26, 2016 Another problem with a roof top wall. Any idea what is causing this? Link to comment Share on other sites More sharing options...
dshall Posted July 26, 2016 Share Posted July 26, 2016 On 7/26/2016 at 2:06 PM, ACADuser said: Another problem with a roof top wall. Any idea what is causing this? I don't know what you did wrong, but paint wall to match siding and all is well, and then copy bad wall and move 2' to side, delete bad wall and move copied wall back where bad wall was and all will be good. What you did wrong, I do not know. Link to comment Share on other sites More sharing options...
dshall Posted July 26, 2016 Share Posted July 26, 2016 BTW, I like your AC unit (3701 faces, shown on right) The AC unit on left from CA library has 9504 faces, lots of faces, the one in the middle is also from CA library, 62 faces..... something to think about. Does anybody have any input on when there are too many faces for a symbol? Link to comment Share on other sites More sharing options...
ACADuser Posted July 26, 2016 Author Share Posted July 26, 2016 Thanks you Mr Hall.. The Partition wall was created as one continuous wall. It has drywall on both sides. I broke the wall as it leaves the stairwell, changed to stucco only on both sides which made the wall off center. Then I used the center tool to move it. That is when the problems started. Your fix worked for me. Thanks Interesting about the AC units. How do you find out how many faces it has? Link to comment Share on other sites More sharing options...
ACADuser Posted July 26, 2016 Author Share Posted July 26, 2016 BTW I can't find the Middle CU in Chief. x7 & x8 here Link to comment Share on other sites More sharing options...
Alaskan_Son Posted July 26, 2016 Share Posted July 26, 2016 On 7/26/2016 at 2:06 PM, ACADuser said: Another problem with a roof top wall. Any idea what is causing this? I'm away from my computer now, but double check that wall definition and see what happens if you turn on your wall framing layer. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted July 26, 2016 Share Posted July 26, 2016 On 7/26/2016 at 4:02 PM, ACADuser said: Interesting about the AC units. How do you find out how many faces it has? Click the little Open Symbol icon and it's in there. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted July 27, 2016 Share Posted July 27, 2016 Just got back to my computer. Select that wall, click on the Materials tab, click on the Interior Wall Surface material, click Select Material, and then check Use Default Material. There is something funny going on with the material definition for that wall. Not sure how it got that way though. Link to comment Share on other sites More sharing options...
ACADuser Posted July 27, 2016 Author Share Posted July 27, 2016 Thanks for the detective work Michael. Link to comment Share on other sites More sharing options...
