Roof top Decking & pitched trusses?
ACADuser
Another problem with a roof top wall.
Any idea what is causing this?
I don't know what you did wrong,  but paint wall to match siding and all is well,  and then copy bad wall and move 2' to side,  delete bad wall and move  copied wall back where bad wall was and all will be good.
What you did wrong,  I do not know.
BTW,  I like your AC unit  (3701 faces,  shown on right) The AC unit on left from CA library has 9504 faces,  lots of faces,  the one in the middle is also from CA library,  62 faces.....  something to think about.
Does anybody have any input on when there are too many faces for a symbol?
Thanks you Mr Hall..
The Partition wall was created as one continuous wall. It has drywall on both sides.
I broke the wall as it leaves the stairwell, changed to stucco only on both sides which made the wall off center.
Then I used the center tool to move it. That is when the problems started.
Your fix worked for me. Thanks
Interesting about the AC units. How do you find out how many faces it has?
Just got back to my computer.  Select that wall, click on the Materials tab, click on the Interior Wall Surface material, click Select Material, and then check Use Default Material.  There is something funny going on with the material definition for that wall.  Not sure how it got that way though.
