Sign in to follow this
archibry
Arc seating?
I have a question about seating (arched - see attachment)
I've been trying this for a while (manually) and was wondering if anybody knows how to do this more precise and easier... well at least more accurate than I can do.
The attachment is not mine, but it gives you an idea of what I'm trying to accomplish.
Thanks in advance.
- Bryan
There was a detailed discussion on this not too long ago, check this out:https://chieftalk.chiefarchitect.com/index.php?/topic/9864-sloped-floor/?hl=%2Bsloped+%2Bfloor
Then let us know if you have any trouble or more questions.
What have you tried so far?
It might be possible with a floor for each level maybe? Would have to give it a try. Depends a bit on the method of construction and drawings required.
What specifically are you having trouble with?
The floor, seats etc.
This is a series of slabs. Do one, then transform replicate the others.
Seats
Looks like you have the chairs all figured out but need something to support them. Does this look anything like what you are after.  If so I can post my test plan for you.  What version are you working with?
Did you use a Distributed Path for the seats?
No, that was the exact option I'm looking for! I'll dig around for a while.
That's looks great to
Chopsaw
Y
es I'm looking for more of a "perfect" way to place the seats. I'm working with 8
Still messing around with the distribution path.  Ahhh it sucks being a beginner!   :huh:
So I'm guessing Spline?
No, not spline.
Select Build... Distributed Objects...Polyline Distribution Path.
Draw a single straight line.
Convert to a curve (Change Line/Arc on the Edit menu).
Open it's dbx and select and configure your seats.
Change arc as needed.
I made this video a little while back for a different situation but it may help you nonetheless. I'm think instead of the spline I would use a polyline.
Here is my test plan that you can check out for settings if you like. And practice distributing chairs with.
Theater Seating.plan
THANKS so MUCH!!!
Only question now is how do I "ungroup" it so to speak?
Everyone here has been super awesome by the way!
I studied the floor up close. More beautiful than I thought at first glance. You did a great job with the overhang and separate "units" I guess you'd say? I like that the floor can be a different color than the steps in-between them. Awesome job!   :)
No, not spline.
What version are you using? I don't see that option under the Edit Menu.
No Problem Archibry, It is really just a big set of stairs that would need some additional engineering to hold a big crowd of people but could be an option for you. You can check the settings and tweak the rise and run as necessary. Adjust materials etc. I did not bother with all the chairs because it looked to me like you already had that figured out at the time. I just threw in a few and set their elevations. All one unit just double click and you will see. Not so sure there is an ungroup for distribution path but it can be edited or deleted or moved and you can turn off the cad path but that might be about all. Michael or Glenn can confirm for you.
Good Luck and keep us posted, Chopsaw
Maybe this will help you a bit.  Just the basics and might answer a couple of your questions...
Step 1:  Build Distributed Objects>Polyline Distribution Path
Step 2:  Draw line and Change Line/Arc
Step 3:  Select object and adjust settings as necessary
Step 4:  Explode Distributed Object  (I thought I went over this step in that video but maybe not)
Step 5:  Delete, move, modify objects as necessary
...and any number of extra steps in between or after those.
Thanks Michael,  That was all in the video but I missed it the first time to.  Always fun to discover a new tool in the toolbox.
You bet.  I feel the same way.
Thanks EVERYONE! ALL Suggestions are great. AND THEY WORK.. (just took ME some time)
See you all when I come back.
Looking pretty good.  Have you decided how you would like to hold all those chairs up yet?
    27475
    slickrick1530
    slickrick1530
