buzzsaw204
Stair Handrail distant from wall
hi,
is there a setting to change the distant of Hand Rail away from wall?
thanks,
No, not that I know of, sounds like a cracker jack suggestion though. I have never had this come up as an issue but if I did need to I would turn off the default stair object hand railing on the indicated side and replace it with a railing made from a 3D molding poly line, yes that is a work around but you did ask.
I do it using a detail of the handrail.
here is a generic detail to help you along
this is for a stair handrail, if guardrail needs to be 42" high
ah ok....i see you point.
thanks
    27825
    ChiefDallas
    ChiefDallas
