mountaineer Posted July 12, 2016 Share Posted July 12, 2016 I'm having trouble getting my first floor walls connecting correctly with the second floor walls. I have all these crazy lines and can't seem to get them to connect. I know this plan is still a mess but the walls are my current struggle. Thanks for any input.... Sample Model.plan Link to comment Share on other sites More sharing options...
ShaneK Posted July 12, 2016 Share Posted July 12, 2016 Use "wall align with below" tool. Link to comment Share on other sites More sharing options...
ShaneK Posted July 12, 2016 Share Posted July 12, 2016 Default wall heights, front gabel roof baseline, interior walls and stairway area. Sample Model.plan Link to comment Share on other sites More sharing options...
mountaineer Posted July 13, 2016 Author Share Posted July 13, 2016 Thanks Shane! I'm struggling with the corners meeting under my dormers? If I pull that attic wall over it won't connects. Also on the side with the double gable porch. If you select the exterior wall and zoom in, there are all these crazy points that don't meet. No matter what I do I can't clean them up. Is it something in my wall setting or maybe because of the roof? I have been banging my head trying to clean up that one little area. Link to comment Share on other sites More sharing options...
ShaneK Posted July 13, 2016 Share Posted July 13, 2016 Take a screen shot and show problem Link to comment Share on other sites More sharing options...
dshall Posted July 13, 2016 Share Posted July 13, 2016 ......Set your walls to default top and bottom heights....... Why do you guys mess around with this? Listen to the solver, do not adjust the bottom and top of walls unless you know what you are doing. I rarely rarely rarely ever need to adjust the bottom or tops of the walls. Do not do it. CA is very good about self adjusting wall heights. Seriously, think about why you are manually changing the default top and bottom heights and then don't do it. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted July 13, 2016 Share Posted July 13, 2016 Scott, Tell us what you really think. BTW, I am in total agreement with you. Link to comment Share on other sites More sharing options...
ShaneK Posted July 13, 2016 Share Posted July 13, 2016 Post #3 agrees with Solver too. Link to comment Share on other sites More sharing options...
