Elevation dimension error on PDF save
skirby19
Go to solution Solved by justmejerry,
This one is new. Any ideas???
I save my layout as normal...Chief to PDF... everything looks perfect with my elevation measurements (see the pic from my phone of page 6 of my file). The Grade level is even with the bottom of the garage door...grade level.
Then after it is save and the PDF is opened...the grade level drops about a foot. (See page 6 of the PDF)
Weird...
I've saved it under a different name, used a different PDF host, opened it on a browser, Can Not figure our what is going on here...
Medlin Plan - Holiday Isle Lot 2 Blk D.pdf
Is this a "Live Elevation"? If you are going to post the file you will need to open the layout and then do a "Backup Entire Plan" in order to have all the data needed to really answer your question. You will likely then need to upload to DropBox due to  file size.
    32647
    pewufilo
    pewufilo
