clfrycreative Posted May 17, 2016 Share Posted May 17, 2016 I've been meaning to ask this for a while, and since I happened to run into it again on a day that I happen to be on the forum... how does one go about changing the ceiling heights in all of (or at least multiple) the rooms on a given floor? In this case, the first floor has a 9' plate and we need to raise everything to 10'... in the past I've opened each individual room, including every closet, dead space, etc, but it is very time consuming, especially on large plans. I've tried selecting all of the rooms and clicking "open", but when I go to "structure", the heights are greyed-out... Link to comment Share on other sites More sharing options...
clfrycreative Posted May 17, 2016 Author Share Posted May 17, 2016 On 5/17/2016 at 8:53 PM, solver said: To change all the rooms, change your default settings -- they will update automatically. Interesting, those values are greyed-out there as well... just like when I select multiple rooms. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted May 17, 2016 Share Posted May 17, 2016 Try using the Match Properties Tool. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted May 17, 2016 Share Posted May 17, 2016 On 5/17/2016 at 9:02 PM, clfrycreative said: Interesting, those values are greyed-out there as well... just like when I select multiple rooms. Try FLOOR defaults and not room defaults. Link to comment Share on other sites More sharing options...
clfrycreative Posted May 17, 2016 Author Share Posted May 17, 2016 On 5/17/2016 at 9:20 PM, Alaskan_Son said: Try FLOOR defaults and not room defaults. That did it. So, for the scenario that I might want to do it for just part of the house, it still needs to be done for each room individually? Link to comment Share on other sites More sharing options...
jscussel Posted May 17, 2016 Share Posted May 17, 2016 Go to Default > Floor as Michael said..................... Link to comment Share on other sites More sharing options...
Alaskan_Son Posted May 17, 2016 Share Posted May 17, 2016 On 5/17/2016 at 9:58 PM, clfrycreative said: That did it. So, for the scenario that I might want to do it for just part of the house, it still needs to be done for each room individually? No. For that, use the Match Properties tool I previously mentioned. If you're not sure how, check "Help". Make the help files your friend. They're an invaluable ally. Link to comment Share on other sites More sharing options...
mthd97 Posted May 18, 2016 Share Posted May 18, 2016 What Happens if this house has a monolithic concrete floor slab that has already been built and you do not want to delete it? In this case multi select roof planes and move them up 1 foot. Link to comment Share on other sites More sharing options...
MickeyToo Posted May 18, 2016 Share Posted May 18, 2016 If it is less than the entire floor, try pulling back the walls between the rooms you want to change the height in a few inches (making it one large room) then simply reconnect them when done. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted May 18, 2016 Share Posted May 18, 2016 On 5/18/2016 at 2:26 AM, MickeyToo said: If it is less than the entire floor, try pulling back the walls between the rooms you want to change the height in a few inches (making it one large room) then simply reconnect them when done. That does work, for anyone unfamiliar with it though... Just bear in mind that if you've customized floor coverings, moldings, wall coverings, etc. for those rooms then you'll have to redo all that work. Link to comment Share on other sites More sharing options...
MickeyToo Posted May 18, 2016 Share Posted May 18, 2016 Good point, Michael. I usually use this method early on when setting up the model and before applying the finish details. Link to comment Share on other sites More sharing options...
glennw Posted May 18, 2016 Share Posted May 18, 2016 On 5/18/2016 at 1:31 AM, mthd97 said: What Happens if this house has a monolithic concrete floor slab that has already been built and you do not want to delete it? In this case multi select roof planes and move them up 1 foot. I would not use this method as all the internal walls and the existing ceilings, etc. will not move up. They will retain their existing heights. If you don't want the slab to rebuild, turn off Auto Rebuild Foundation. The best way to change some of the rooms, IMHO, is to use the Match Properties tool as Michael has suggested. Change just 1 room to what you want. Select that room. Click Match Properties from the Edit toolbar. Click Select All. OK. Select Apply Properties from the Edit toolbar. You can now "paint" those properties on to as many rooms as you want. Link to comment Share on other sites More sharing options...
