ChiefMC Posted May 9, 2016 Share Posted May 9, 2016 I hope this is something simple that I am missing.... There have been instances where I need to show a closet shelf & rod dying into a 45 degree wall. Can someone point me in the right direction on how to clip off a corner of a shelf or any object for that matter? Thanks! Link to comment Share on other sites More sharing options...
Chopsaw Posted May 9, 2016 Share Posted May 9, 2016 There will likely be many correct answers to you question but if you need to show a detail like that you may want to switch to using a polyline solid which gives many more options for shape. The rod would be a little more difficult but could be done with a Cylinder. Is it an inside or outside corner? You could just show an end cap (Partition) and let the carpenter decide if he wants to build into the corner. There is some intelligent discussion about 45 degree shelves in this post but even I do not understand how it was accomplished so maybe if you were to ask then we would all know. https://chieftalk.chiefarchitect.com/index.php?/topic/3443-shelf-and-rod-suggestion/?hl=shelf Link to comment Share on other sites More sharing options...
johnny Posted May 9, 2016 Share Posted May 9, 2016 MC - good question. You are right, a serious limitation to the shelve tool. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted May 9, 2016 Share Posted May 9, 2016 Try using the CounterTop Tool instead. But I agree that any such object - including Cabinets - should be able to be "back angled". Link to comment Share on other sites More sharing options...
