Special window
DTCBuild
If you do not have a window to take a picture of you can build one in Chief if you have the patients. Just construct your double hung or fixed glass window and open an elevation view of it and then apply 1/8" poly line solids in your pattern and change the material to a textured glass from the library ( I used "Corsica" ) then use the "Adjust material Definition"  tool to change the colour and shade the glass. Finish off by drawing a cad line in each joint and convert them to "3D Molding Polyline" (s) and you are done.  It only take a few minutes, just kidding, not the first time.  Good Luck.
How about the glass, any questions?
I did my Muntins wrong please forgive me. Always learning with Chief but I don't think I like those tools that only appear after 5 or 6 criteria are met.  Makes them hard to remember.
