Changing walls library
johnny
Johnny,
I am not sure if you can do that directly.
But once you have placed a wall from the library into the plan (just place a short length anywhere), it will become available in the Wall Type Definitions dbx.
You can then select all the existing walls that you want to change and then  change them to your new wall type from the drop down list in Wall Specification dbx.
We probably need Replace From Library to apply to walls as well as other objects.
