zowie123 Posted April 13, 2016 Share Posted April 13, 2016 Hi, I have a 1.5 story house with attic rooms. I would like to fill those attic rooms with R-48, and have R-38 in the vaulted center room. We don't have the ability to input roof R-Values, so I'm assuming I have to use a ceiling or floor. Does anyone know the most accurate method of using Rescheck in this situation? Thanks very much, Barry Seattle now accepts rescheck for energy code--it would brilliant if I could get accurate output for all remodel configurations Link to comment Share on other sites More sharing options...
DRAWZILLA Posted April 13, 2016 Share Posted April 13, 2016 Have you tried to export to Rescheck? remodeling is tough, you have a lot of set it up first. Link to comment Share on other sites More sharing options...
zowie123 Posted April 14, 2016 Author Share Posted April 14, 2016 Hi Perry, I just spent the afternoon screwing around with this. It's not possible to get good results. Chief exports all the walls, doors and windows but with different labels so you don't know what you're looking at in Rescheck. If the labels were consistent with the wall labels on the plan, perhaps I could figure out what's what and manually edit in rescheck. It would be easier to start from scratch in Rescheck which doesn't save time. I find it useless, but if anyone out there has figured it out, please let me know. Thanks, Barry Link to comment Share on other sites More sharing options...
DRAWZILLA Posted April 14, 2016 Share Posted April 14, 2016 Never tried it b/c we in Calif. have our own title 24 rules, so the export doesn't work for us. They say it works for Rescheck, who knows, maybe someone actually using it can chime in. Link to comment Share on other sites More sharing options...
BrownTiger Posted April 14, 2016 Share Posted April 14, 2016 >I just spent the afternoon screwing around with this. It's not possible to get good results. Why? Export rxl, import it into rescheck. All your walls should be listed. Adjust R settings as needed. >We don't have the ability to input roof R-Values, so I'm assuming I have to use a ceiling or floor. Where exactly you can NOT enter R value? At least with Rescheck 4.6.2 any R value can be overwritten. >I would like to fill those attic rooms with R-48 Select your ceiling, click on Cavity insulation R value - enter 48 WHat is the issue? If you don't like Row that it generated: right click - delete, hit ceiling add manually your ceiling plane. Brown Or if you Need Heat/Cool Load 1) Download & Install HeatCad (30 day free trial) 2) Use CA export ALL Floors as DWG 3) Open HeatCad create new project, set defaults 4) Main floor 5) Import DWG and turn off all layers but level_1 6) quickly trace project, place windows 7) adjust North Directing thingy 8) generate report. Link to comment Share on other sites More sharing options...
Mark_Peterson Posted April 15, 2016 Share Posted April 15, 2016 Drawzilla, I was wondering if ResCheck would work for Title 24 here in California, so in your experience, it doesn't pass muster? Link to comment Share on other sites More sharing options...
DRAWZILLA Posted April 15, 2016 Share Posted April 15, 2016 No, here you have to use the state's program (calres, it's free to download) or purchase one that is accepted by California. Chief's export does not work with any of those. Link to comment Share on other sites More sharing options...
Mark_Peterson Posted April 17, 2016 Share Posted April 17, 2016 Bummer, thanks Drawzilla. Link to comment Share on other sites More sharing options...
