rlackore Posted April 11, 2016 Share Posted April 11, 2016 Is there a method to achieve this: to hide under-cabinet lighting, without having to apply a molding to the bottom? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 11, 2016 Share Posted April 11, 2016 I've never tried this, and I'm away from my computer, but could you use a base cabinet with a toe kick for that area? Link to comment Share on other sites More sharing options...
rlackore Posted April 11, 2016 Author Share Posted April 11, 2016 I've never tried this, and I'm away from my computer, but could you use a base cabinet with a toe kick for that area? That is a lot more complex work-around than adding a molding to a wall cabinet. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 11, 2016 Share Posted April 11, 2016 That is a lot more complex work-around than adding a molding to a wall cabinet. I personally don't think the molding is complex or a workaround. I was just trying to offer an alternative. Not exactly sure what you're overall goal is it what your issue with the moulding is but the toe-kick thing is just what came to mind. Link to comment Share on other sites More sharing options...
rlackore Posted April 11, 2016 Author Share Posted April 11, 2016 I don't know a lot about how cabinets are built, but I was assuming that there must be a "standard" way of modifying the box construction without tacking on a molding at the bottom. So I was wondering if there was a something in the cabinet dbx that I was missing. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 11, 2016 Share Posted April 11, 2016 Gotcha. Yes there is a way of doing that without tacking molding onto the bottom in real life. I've never attempted to do that in Chief though. That's the type of thing I would just note on my cabinet plans. Link to comment Share on other sites More sharing options...
MarkMc Posted April 11, 2016 Share Posted April 11, 2016 Like Michael I usually just note it- I also add a CAD detail as typical. IF you really must make one in a frameless cabinet in CA here is one way-library with example attached. A framed cabinet will have an appropriate recess. edited to add-note that it will be incorrect in the cabinet schedule since the height is cheated. recess bottom wall cabinet.calibz Link to comment Share on other sites More sharing options...
MarkMc Posted April 11, 2016 Share Posted April 11, 2016 I just noticed that if the bottom separation is changed to anything more than 1-1/2" with a framed cabinet the recess disappears- guess that is what you are running into? I only put in LEDs so standard recess is adequate for what I do. Only work around is as on a frameless cabinet (not worth the effort IMO) But it would be nice if they changed it so you could increase the bottom and keep the recess. Link to comment Share on other sites More sharing options...
rlackore Posted April 11, 2016 Author Share Posted April 11, 2016 But it would be nice if they changed it so you could increase the bottom and keep the recess. Yep. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 11, 2016 Share Posted April 11, 2016 Just got back to my computer and played around with it for a bit. I think the quickest and most accurate method to achieve what you're looking for is by setting that lower face item to be an inset side panel. The bottom of the box could be built either using a Separation or by placing a shelf manually...and then if necessary, use the vertical overlap as Mark suggested to make the door look right (would require a taller separation at the top as well). If you don't need the extra door overlap, just skip that last step. Link to comment Share on other sites More sharing options...
