bjparsons1 Posted April 7, 2016 Share Posted April 7, 2016 I just downloaded X-8 and can not find a tool to edit roof finishes, for example changing from the standard asphalt shingle to a standing seam metal. What am I missing? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 7, 2016 Share Posted April 7, 2016 Structure tab Link to comment Share on other sites More sharing options...
johnny Posted April 7, 2016 Share Posted April 7, 2016 ....or use the Material painter when in 3D view. You can then experiment with different types of materials, and if you want to adjust something slightly use the "rainbow" Adjust Material Definition tool. Link to comment Share on other sites More sharing options...
Geyatautsilvsgi Posted April 11, 2016 Share Posted April 11, 2016 I used the material painter and that worked for what I am doing now. However, I am curious, is there only the one color (blue) for the asphalt shingles? I have tried to change the color but every time I do, it shows a solid color with no texture. Is is possible to have the asphalt shingle texture in different colors? Not, shakes or cedar shingles.... Link to comment Share on other sites More sharing options...
Joe_Carrick Posted April 11, 2016 Share Posted April 11, 2016 Make the changes in Build Roof>Edit All Roof Planes. That way you can select the material from the Library. Link to comment Share on other sites More sharing options...
