centering labels
KevinRAmbrose
Actually, if you use a User Macro you can format the entire label to be centered.  You just need to use the method ".center(20)" for each line.  You will also need to use "\n" where you want a line feed.
Basically something like this:
result = line1.center(20) + "\n" + line2.center(20)
