Joe_Carrick Posted April 5, 2016 Share Posted April 5, 2016 If you create Text and set it to "Use Text Style" and then create a Block with other CAD Objects and add that to the Library ..... The Text displayed in the Library will not be "to scale" with the rest of the graphics. OTOH if you set the text to "Use Layer for Text Style" or "Use Custom Text" it will be "to scale" with the rest of the graphics. This is something that I never figured out before and was very frustrated when I found a CAD Block in the Library that had a mess of Text and I couldn't see what the #@&! it was supposed to be. 2 Link to comment Share on other sites More sharing options...
DRAWZILLA Posted April 5, 2016 Share Posted April 5, 2016 Thanks Joe, I'll check it out. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 5, 2016 Share Posted April 5, 2016 Thanks for the info Joe. I know I've had issues with text and CAD blocks in the past as well. You may have very well pointed to the culprit. Link to comment Share on other sites More sharing options...
