baynesjosh Posted March 28, 2016 Share Posted March 28, 2016 I am having a hard time building a pergola. I am assuming the easiest method is using polyline solids to represent posts and rafters. But I am not sure is there are easier ways to create the end cut details. I have been doing it all with lines to generate the ends that I want but then I can't duplicate it on the other side. There must be an easier way Link to comment Share on other sites More sharing options...
Joe_Carrick Posted March 28, 2016 Share Posted March 28, 2016 Look in the Library under Millwork for rafter ends. Also, be aware that you can can use Framing Members (Posts, Beams, Joists, Rafters, General Framing Members. Or, you could also build a room and frame it then make the walls invisible, etc. There are a lot of ways to do this. Link to comment Share on other sites More sharing options...
winterdd Posted August 9, 2022 Share Posted August 9, 2022 On 3/28/2016 at 2:32 PM, Joe_Carrick said: Look in the Library under Millwork for rafter ends. Also, be aware that you can can use Framing Members (Posts, Beams, Joists, Rafters, General Framing Members. Or, you could also build a room and frame it then make the walls invisible, etc. There are a lot of ways to do this. Fast forward 6 years later! Can we apply custom rafter tails to general framing members? Building one of these puppies now in X13. Link to comment Share on other sites More sharing options...
robdyck Posted August 9, 2022 Share Posted August 9, 2022 32 minutes ago, ChiefUserBigRob said: Fast forward 6 years later! Can we apply custom rafter tails to general framing members? Building one of these puppies now in X13. draw a gen. framing member; double click; end profile. 1 Link to comment Share on other sites More sharing options...
winterdd Posted August 9, 2022 Share Posted August 9, 2022 26 minutes ago, robdyck said: draw a gen. framing member; double click; end profile. that is is the first thing I did and skipped right over "end profile". thanks man......guess I was looking for rafter tails option. Link to comment Share on other sites More sharing options...
robdyck Posted August 9, 2022 Share Posted August 9, 2022 18 minutes ago, ChiefUserBigRob said: that is is the first thing I did and skipped right over "end profile". thanks man......guess I was looking for rafter tails option. That happens! You should post an image of your pergola once it's pretty much done... Link to comment Share on other sites More sharing options...
winterdd Posted August 9, 2022 Share Posted August 9, 2022 5 minutes ago, robdyck said: That happens! You should post an image of your pergola once it's pretty much done... i sure will...... Link to comment Share on other sites More sharing options...
winterdd Posted August 9, 2022 Share Posted August 9, 2022 1 hour ago, robdyck said: That happens! You should post an image of your pergola once it's pretty much done... Not too bad of a pergola/backyard makeover just to show for reference on my sunroom addition per the client's request. Damn I love my 3080 card. 1 Link to comment Share on other sites More sharing options...
