English Posted March 24, 2016 Share Posted March 24, 2016 Please look at my screen shot and see why that wall is not displaying. Invisible walls are on. What is showing is a wall polyline and I can open it and it's set as Siding, 4. The other side of the porch is the same -- no wall. Not sure why it's an odd shape with the "spike". Thanks Alan Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 24, 2016 Share Posted March 24, 2016 Plan? Link to comment Share on other sites More sharing options...
DavidJPotter Posted March 24, 2016 Share Posted March 24, 2016 I do not specialize in "why" but I do specialize in "how do you fix it". Walls are defined by "Wall Poly-Lines" as shown in your posted image. Why they go where they go is better addressed to Chief Architect Inc Software Engineers. But they do have "Edit Handles" when selected which means that you can edit them or redraw them. Explaining why they do what they do I will leave to the persons who wrote the code that defines their behavior. I work with them and appreciate the mostly positive things that they do. Most of the time, working with them I can get a positive result and that is good enough for me. DJP Link to comment Share on other sites More sharing options...
English Posted March 24, 2016 Author Share Posted March 24, 2016 I can't send the plan but I did recreate it in another which is attached. Thanks Alan TEST.plan Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 24, 2016 Share Posted March 24, 2016 Thanks. That works. I think you'll find that a wall's polyline always stops at the midpoint of the adjacent wall. I'm assuming this has something to do with the internal workings of the program and the way it decides how to make wall connections, build rooms, etc. Anyway, what you're seeing is the polyline of that invisible wall including all areas that it is affecting...which again extends halfway through the thickness of that exterior wall. Link to comment Share on other sites More sharing options...
English Posted March 24, 2016 Author Share Posted March 24, 2016 Michael So it will always do that? I have to add a solid polyline and eye drop off the siding so the elevation looks right. I think I'll submit it to tech support. ThanksAlan Link to comment Share on other sites More sharing options...
Solution rlackore Posted March 24, 2016 Solution Share Posted March 24, 2016 Please look at my screen shot and see why that wall is not displaying. Invisible walls are on. Those walls are set as Invisible. Uncheck Wall Specification>General>Options>invisible and they will show up. AFAIK, turning on the layer Walls, Invisible doesn't matter in 3D view, only plan. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 24, 2016 Share Posted March 24, 2016 Michael So it will always do that? I have to add a solid polyline and eye drop off the siding so the elevation looks right. I think I'll submit it to tech support. Thanks Alan Sorry, I think I misunderstood your question. As Robert said, just uncheck Invisible and you should be good to go. You knew they were invisible walls. I guess I assumed you knew how invisible walls worked. Link to comment Share on other sites More sharing options...
English Posted March 25, 2016 Author Share Posted March 25, 2016 Yes I found out that the wall was in the attic and one part of that wall is visible and the other is invisible. I just dragged the visible wall over the invisible one and voila -- now all is good. Alan Link to comment Share on other sites More sharing options...
