BethVanDeusen Posted March 17, 2016 Share Posted March 17, 2016 The cabinet labels on the side wall of the attached plan will not face the way I want. They are currently facing the wall and I want them rotated 180. When I do this, they automatically revert to the current orientation. I have played with the settings but to no avail. Any ideas??? Link to comment Share on other sites More sharing options...
MarkMc Posted March 17, 2016 Share Posted March 17, 2016 here ya go labels.pdfFetching info... Link to comment Share on other sites More sharing options...
Dermot Posted March 17, 2016 Share Posted March 17, 2016 It's a standard drafting convention that all of your vertical and horizontal labels will always face the same direction. So it's going to be normal for cabinet labels to face the wall sometimes. There are a couple of easy things you can do if you want to change this though. - If you would prefer to have all of your cabinet labels horizontal instead, you can set the label angle to "absolute" and 0 degrees in the cabinet dialog. - If you really want some of your vertical labels to be flipped around, set them to be 180.01 degrees which will prevent the program from flipping them back automatically. Unfortunately, this won't work on the horizontal labels but I'm not sure that you would really want those upside down. There may be other suggestions but these are what I came up with that are easy. 1 Link to comment Share on other sites More sharing options...
CJSpud Posted March 17, 2016 Share Posted March 17, 2016 Thanks Dermot .... Link to comment Share on other sites More sharing options...
BethVanDeusen Posted March 17, 2016 Author Share Posted March 17, 2016 Thanks Dermot. I get the reasoning but on a cabinet plan I want the labels facing the room. Your solution worked. Link to comment Share on other sites More sharing options...
