Evolution Posted February 24, 2016 Share Posted February 24, 2016 A project I'm working on for my day job, I have imported the cad blocks of furniture for the admin area I was attempting to use for a 3D model to present to the client, whom wished not only to see the offices but the exact furnishings that we would be providing. Attempts to get the 3D to show the furniture not working, and I am a little behind the 8-ball trying to determine if it is even possible to convert the Cad block into a usable Chief 3D image? Both plans won't attach at the same time so I posted the cad of the floor plan and a second post may allow me to post the Furniture cad blocks. HF MHS Admin offices.plan Link to comment Share on other sites More sharing options...
Evolution Posted February 24, 2016 Author Share Posted February 24, 2016 I can't get the saved furniture cad blocks to post. Even though I select and open they won't attached. They're not that large, Is there some way to drag them from one plan into the other already posted and repost? Link to comment Share on other sites More sharing options...
MarkMc Posted February 24, 2016 Share Posted February 24, 2016 Zip the file should work to upload. Are those already in your plan? just guessing here but there are quite a few CAD blocks in it-all are 2D. Link to comment Share on other sites More sharing options...
jcaffee Posted February 24, 2016 Share Posted February 24, 2016 Just a bunch of 2D data. Replace with 3D symbols and you'll be cooking with gas. jon Link to comment Share on other sites More sharing options...
johnny Posted February 24, 2016 Share Posted February 24, 2016 What everyone else is saying is key - the person you got this file from simply exported 2d (which may be all they have). You should just start placing your own furniture - unless they are using a particular brand of office furniture. Then you will have a lot of work in front of you if that company doesn't provide their system in 3D. Link to comment Share on other sites More sharing options...
Evolution Posted February 24, 2016 Author Share Posted February 24, 2016 Jon and Mark, they sent me the CAD file first (I imported w/all cad blocks, maybe I should have turned them off) anyway, the Furniture sent the Furniture she said it was the 3D cad block but it doesn't import that way? I don't need anything but her furniture for what I'm currently task with. And, Mark, for whatever reason when I attempt to attach the furniture cad block using browse, it won't let me even select that file although it is saved in X8. I may have to down load the original to a thumb drive and then do the browse, I don't know. Thanks, Link to comment Share on other sites More sharing options...
MarkMc Posted February 24, 2016 Share Posted February 24, 2016 Did you just drag them in? If you drag in 3D files they come in as 2D blocks AFAIK. There are quite a few cad blocks in your plan (go to CAD block management) If you want them as 3D -import as symbol. Link to comment Share on other sites More sharing options...
Evolution Posted February 25, 2016 Author Share Posted February 25, 2016 Did you just drag them in? If you drag in 3D files they come in as 2D blocks AFAIK. There are quite a few cad blocks in your plan (go to CAD block management) If you want them as 3D -import as symbol. Thanks Mark. I've had to table it for now, and by the time I get back to it, probably won't need it. I will keep it to work on later (when I do get the time). Thankfully this is not a mandate from the client. Ha! Link to comment Share on other sites More sharing options...
