Sign in to follow this
johnny
Molding Poly To Solid
Is there a way to covert a molding poly with the profile into a solid that can be joined or subtracted with other solids?
Not that I know of. I wish there was. I made a request a while back. I would encourage you to make it again. In the meantime you can just extrude a polyline in the appropriate shape and use that. Downside of course is that you can only essentially use one moulding line at a time.
If you have the appropriate software you can export the geometry and convert to solid then do the req'd operations and return to Chief as a symbol.  Symbol placement can become an issue in certain circumstances, but there are ways to deal with that.
I would also add that being able to covert not only molding poly, but also framing would be very useful.
You don't have to export the molding polyline to another app.  Just display it in 3D and convert to Symbol.
Another thing that is possible is to create a "Face" - either by using the "Solid Face" tool or exploding a 3D Solid.
The Face can be extruded to form a Solid.
It's a little tricky to learn the process and what parameters to use for the extrusion, but once you get the hang of it......
    27602
    Floriance
    Floriance
