Why Does The Brick Pattern Not Appear In Exterior Elevations In Layout
KerlDesign
When I send my exterior elevations to a layout page, the brick pattern no longer shows.  The roof pattern, stone wall pattern and siding pattern are all still visible; however, the brick pattern is not.  When I print, the brick pattern is not there.  Is there a control I need to change for it to appear?
The most common cause for this is that many brick and tile materials have "white lines" set as their default, I have to change the white lines to black lines, if I want them to print. You click on the material with the "Adjust Material" (tri-color) tool and on the general tab make the white lines black, it is that simple. White on white does not print.
