Sign in to follow this
antman
Schedule Image Row Height Control
It seems like the ability to adjust schedule columns is the same, but when images are added to a schedule, even with "Scale Images" box checked, the rows are not sized correctly - see attached image.  This makes my electrical (and any other) schedule way too long where it fits nicely when there are no images.  It appears that all rows are set to the height of the largest image.  On the window schedule, it sets all rows to a height that enables the largest window to be seen.
Is there a way to adjust row height?  Or is this be something Chief could fix?  Ideally, row height would be an auto-adjust so it is relative to the size of each image.
Make sure in your Schedule Default that "Scale Images" is turned off.
Also, by adjusting the column width of the Image column, this will adjust the row height.
Jon
Jon is correct but might be best for things like electrical where you don't need things 'scaled'. That first schedule is 'scaling' the larger fan and all the other symbols are following that size row height.
With windows you might want to 'scale' the images to show that one window is smaller/larger than another.
Might take some experimentation but should/could be workable.
Antman How did you create the door schedule with the photo's of the doors on the left ?
Hey Dave, This is the DBX for the 3D Views, Your choice of 3 with X8.
    27825
    ChiefDallas
    ChiefDallas
