Large Empty Layout
chuck_g
Go to solution Solved by KirkClemons,
  • Solution
How do you typically create new layouts and update your template?
There seems to be a lot of older data from X6 and maybe older in this file. There are even references to objects that would normally be in a plan file, not a layout file. This is probably what's adding to your file size.
I would recommend copying your title block into a new layout and saving the new layout file as a template.
Yep, that's what I'll do. I was just wondering if there was something I was missing. Thanks to all that had a look.
    32065
    Shatimwene
    Shatimwene
