ctjensbr Posted April 19, 2014 Share Posted April 19, 2014 I am gettin back into designing with Chief Architectafter several years away from it. I have a Windows Vista pc I have a full seat of Chief Architext 10. I have the little purple ish hasp (USB) I get Chief Architact installed and it prompts me to download the "Vista" update and and I do that with know apperent problems. i know insert the Hasp and wait for it to light up and try to launch Chief. I then get a window that pops up. it is a "CANNOT REGISTER" window and the window says: YOU MUST BE AN ADMINISTRATOR IN ORDER TO INSTALL THIS PRODUCT. PLEASE CONTACT YOUR SYSTEM ADMINISTRATOR FOR ASSISTANCE. I am logged in as admin. anyone have a fix for this or know why i am getting this message? thanks Link to comment Share on other sites More sharing options...
lbuttery Posted April 20, 2014 Share Posted April 20, 2014 do some searches on the old forum there were some who were able to get ver 10 to run on Vista properly you could go to CA's website and find the correct driver download however, ver 10 wasn't written for Vista so you may find some "issues" also, try right clicking on the ver 10 .EXE and select "run as admin..." Lew Link to comment Share on other sites More sharing options...
rgfeher Posted April 20, 2014 Share Posted April 20, 2014 also, try right clicking on the ver 10 .EXE and select "run as admin..." Lew definitely worth a try Link to comment Share on other sites More sharing options...
Bill_Emery Posted April 20, 2014 Share Posted April 20, 2014 i still run version 10 occasionally on vista; it's been years since I set it up, but I believe that it runs in the XP compatibility mode. Link to comment Share on other sites More sharing options...
ctjensbr Posted April 20, 2014 Author Share Posted April 20, 2014 THANKS LEW THAT WORKED GREAT ! RIGHT CLICK AND CLICK RUN AS ADMIN. TO THE OTHER ABOUT RUNNING ON VISTA...THERE IS AN UPDATE ON CHIEFS WEBSITE TO ET IT TO RUNPROPERLY. THANKS AGAIN Link to comment Share on other sites More sharing options...
Doug_Park Posted April 20, 2014 Share Posted April 20, 2014 If you are serious about using Chief to do production work on modern hardware I would highly encourage an upgrade. Version 10 barely ran on Vista. If you are going to stay with version 10 I would recommend running XP. X2, 2 versions newer than Version 10, was the first version of Chief to fully adapt to the more modern Vista based operating systems. We have also done a lot of work to improve performance on modern systems by supporting multiple cores and more modern video cards. 1 Link to comment Share on other sites More sharing options...
lbuttery Posted April 20, 2014 Share Posted April 20, 2014 I would recommend running XP However, note that Microsoft no longer supports XP so don't connect to the internet at all ever to avoid virus's etc If you do upgrade Chief, I would recommend avoiding X3 due to significant hassles with the library system probably best to get X4 or later Lew Link to comment Share on other sites More sharing options...
