Current Printer For Chief? What Are You Using?
HumbleChief
  On 12/10/2015 at 10:23 PM, builtright3 said:
I just spoke to an HP sales rep and he said if your HP110 is still working good that he wouldnt replace it with the T120 or 520 because its not that much of a difference in speed and the print quality. I know I have been real happy with mine. He also said they were having an issue with the display screen going blank when there was an error. I guess its not the big of a deal but still no need to replace if you existing printer is working fine. I think the newer models may not be a durable as the older models (just a hunch).
Thanks Joey
We use several Epson SC-T7000 and the 5000. Excellent quality........ test file
1st)720x1440 dpi full color  24 x 36        1 minute15 seconds  from the time I pressed OK to print and auto cut........ Black and white 1minute and grayscale 1:20
same criteria
2nd)Same plan 360 x 720 dpi....... 40 seconds   color
3rd)Same plan  1440 x 1440 dpi........... 2:25 minutes  color
Hope this helps.
kevin
I use an Epson Workforce ( about $200 ) and buy 12 x18 Paper online so I can get pretty accurate 1/8" scale check sets and send out for 24x36 sheets or larger. Works great and fairly cost effective.
Several companies make printers that will do up top 13x19 prints/ photos
