tahoebrian5 Posted December 6, 2015 Share Posted December 6, 2015 I apologize in advance, it seems like the simplest things hang me up in the learning process. Anyway, I have created my basic model and created the 4 exterior elevations which I'm nearly ready to send to my layout sheet. I would like to have just a simple black and white line drawing of the elevations. When I turn off color instead I get shading between the lines. How do I get a view without shading? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted December 6, 2015 Share Posted December 6, 2015 If it's a vector view, it will become a simple black and white line drawing when sent to layout. Link to comment Share on other sites More sharing options...
tahoebrian5 Posted December 6, 2015 Author Share Posted December 6, 2015 I'm not sure how to make it a vector view. I've tried selecting vector view but it does not appear to change the view Link to comment Share on other sites More sharing options...
tahoebrian5 Posted December 6, 2015 Author Share Posted December 6, 2015 I guess I'm asking for a step by step here. You would think it would be a simple thing. The only way I've had any luck is editing the materials and changing the color to white. I'm pretty sure that is not the right way to do this though. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted December 6, 2015 Share Posted December 6, 2015 Have you tried sending a view to layout yet? 1 Link to comment Share on other sites More sharing options...
DRAWZILLA Posted December 6, 2015 Share Posted December 6, 2015 In preferences set "color off" to black and white but everything will be black and white. I use Grayscale and get black and white vector views. Could be in the camera setup. Post the plan and get a quick answer. Link to comment Share on other sites More sharing options...
tahoebrian5 Posted December 8, 2015 Author Share Posted December 8, 2015 Ok, when I sent it to layout it displays correctly. Definite case of user error! Next problem, I've chosen vector view which I understand allows object snapping to elevation lines. I can't get any snaps to work on the elevation except the bottom of the roof fascia. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted December 8, 2015 Share Posted December 8, 2015 What is your reason for object snapping in the Elevation View? If it's for dimensions don't worry about it. The Dimension Tools use appropriate Objects. It does seem that Object Snaps should work to anything in the Elevation but only seem to recognize Roof Planes. OTOH, they work to just about everything a Section View. Link to comment Share on other sites More sharing options...
tahoebrian5 Posted December 8, 2015 Author Share Posted December 8, 2015 I like to put an elevation tag on the low point of natural grade and then dimension from there to highest ridge. This is a local thing the building department requires here. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted December 8, 2015 Share Posted December 8, 2015 Draw a Horizontal Line thru those points and dimension to those CAD Lines. Link to comment Share on other sites More sharing options...
