hole in tube
Dennis_Gavin
Due to time constraints I used an image.
Robert - how did you go about your process?  I cannot tell from your picture.
The symbol is just parts built from primitives - took about 1 minute. I created the Material texture image in Genetica (by Spiral Graphics), but it could just as easily be created in Gimp or Photoshop using the Selection tool to select areas to make transparent; then save the image as PNG file to preserve the transparency and use it in the Chief Material.
