low roof high roof issue
barkingeater
You can get close to zero overhang manually by adjusting the eave roof edges but true zero overhand is problematic in terms of 3D modeling (roof planes must cut off wall tops by overhanging them at least a little as 1/16" of an inch really. You are always more likely to get useful answers posting a copy of your plan than otherwise. You also have to describe your problem so that anyone can quickly understand in detail what you are having difficulty with (your post above does not clearly communicate exactly what is going on that needs a solution),
In plan view:
1 - Grab the roof edge @ 1 in this picture, drag back and snap to the surface of the adjacent wall.  That will cure the problem with that wall not building correctly.
2 - To have zero overhang, grab the roof edge @ 2 in this picture, drag back and snap to the surface of the wall it's above.  Then look in 3D.  If the wall is shooting up past the roof, go back to plan view and drag it back out by 1/2" or so.  Repeat until 3D looks correct.
