Victorian Libraries
Askod1
My best advice is to build up your own library of early moldings as you need them. As for corbels and such (aka. symbols), yes you can find them on 3Dwarehouse, but I've found that most of the time they aren't exactly what I was looking for. most of the time I need some item to match an original. Learn to build your own symbols either with CA or Sketchup. I've found that about 90% of all the items needed can be accomplished with CA. As for Sketchup, the posibilites are unlimited and you should make it a priority to learn to use the program.
