AriseDesign Posted August 14, 2015 Share Posted August 14, 2015 Wish Chief already had a solution for this - lazy programming IMO. Sills should be the same when mulling door or window units....tired of looking for workarounds Link to comment Share on other sites More sharing options...
Greg_NY61 Posted August 14, 2015 Share Posted August 14, 2015 In reality, you really don't mull the window and the door together... If you want to do that, you would have to make a special frame for the window and it would have to be done by a manufacturer. Link to comment Share on other sites More sharing options...
AriseDesign Posted August 14, 2015 Author Share Posted August 14, 2015 I know, but since we use Chief to create CDs and not manuals, a door and window(s) are typically shown mulled together. The trim guys will take care of that in the field.... I am asking Chief to be consistent on their programming because nobody on earth will trim/mull units like that....unless the trimming crew do not know what they are doing Link to comment Share on other sites More sharing options...
tommy1 Posted August 14, 2015 Share Posted August 14, 2015 On 8/14/2015 at 4:44 PM, AriseDesign said: Wish Chief already had a solution for this - lazy programming IMO. Sills should be the same when mulling door or window units....tired of looking for workarounds I agree. I have to deal with this all the time. There is another issue too with mulled units and the window schedule that I have brought up before. Either Dan or Doug already confirmed the behavior and said that they will present it to the programing dept. but it was not fixed in the last update. Do I know how to fix it? Yes. Link to comment Share on other sites More sharing options...
RL-inc Posted August 19, 2015 Share Posted August 19, 2015 I have similar troubles with lintels when mulling door and window units together. If I want an oversized lintel with an extended head I have to add manually. If lintels are checked when mulling the units all kinds of crazy trim looks are produced Link to comment Share on other sites More sharing options...
