Changing Gutter Material
Rich_Winsor
Why can't we change the material for the default gutter
molding once the roof has been built? When I first build
the roof I have the opportunity to change the gutter
material in the "Build Roof" dbx but once the roof has
been built there is no longer an option to change the
material in the "Roof Plane Specification" dbx. What's
up with that? Very inconvenient.
Yeah but if I do it that way the change doesn't "stick". For
instance in "Full Perspective Overview" if I subsequently
change the "Active Layer Set" to something else like "All
On Set" and then change back to "Camera View Set" the
material reverts back to whatever was defined during the
initial roof build and ignores my changes.
Thanks fellas, interesting that this seems to be a problem especially
for people named Richard.  :huh:  I guess I will need to have another
play with this to see what is going on. It seems to me that if the gutter
layer is locked you shouldn't be able to edit it, but if it is unlocked it
should show up as an editable option in the "Roof Plane Specification"
dbx. You should also have the "no molding on selected edge" option
here too. It would make controlling gutter behavior a lot easier IMHO.
