RobUSMC Posted February 22, 2014 Share Posted February 22, 2014 I am working on a plan that a previous design intern started and for the life of me I can figure out the issue with the room heights. The kitchen is a default 9'. I am stack cabinets in the kitchen and have a 90" tall cabinet with a 15" wall cabinet sitting on top of it. (105") I have the crown offset 3" past the top of the cabinet as I have done for years. With the additional 3" of height I should be at 108" and the crown hitting the ceiling but it's coming up short by 7/8". As a test i placed a soffit on the slab in the middle of the room that was 108" tall and it does hit the ceiling. None of the cabinet s are set to use the finished floor as we install our cabinets being flooring goes in. I've uploaded some screen shots and the plan to see if anyone sees the issue. Ive never had this happen before and the plan template is the same one if have been using for years moving from X-2 to now. Thanks Rob Link to comment Share on other sites More sharing options...
RobUSMC Posted February 22, 2014 Author Share Posted February 22, 2014 I'm trying to upload the plan but its 32 MB Link to comment Share on other sites More sharing options...
lbuttery Posted February 22, 2014 Share Posted February 22, 2014 Rob: you can either clone the plan then strip out unnecessary parts to reduce size or use Dropbox or sugarsync or .... Lew Link to comment Share on other sites More sharing options...
RobUSMC Posted February 22, 2014 Author Share Posted February 22, 2014 yea i just copied and stripped it down but still at 19MB Link to comment Share on other sites More sharing options...
RobUSMC Posted February 22, 2014 Author Share Posted February 22, 2014 I use DB but have never linked anyone to it Link to comment Share on other sites More sharing options...
RobUSMC Posted February 22, 2014 Author Share Posted February 22, 2014 See if this works https://www.dropbox.com/s/wythg8i4xn68ut0/Humes%20Design%20-%20Drop%20Box.plan Link to comment Share on other sites More sharing options...
mgabriel Posted February 22, 2014 Share Posted February 22, 2014 Your 108" dimension is from finish floor to finish ceiling. You have a 5/8" finish floor system so your stacked cabinets need to be 108 5/8" to the top of the crown if you are sitting your cabinets on the subfloor. Link to comment Share on other sites More sharing options...
GeneDavis Posted February 23, 2014 Share Posted February 23, 2014 Looks like it is 108" clear to me. 109 1/8" rough, less 1/2" ceiling, less 5/8" floor finish. Your DB link is done this way. Going to your ONLINE dropbox, right clicking the file, should give you the "copy public link" option. Do that, and paste the public link to your post here. In a cross section view, use the tape measure or end to end dimensioning to find your shortfall. It may be due to your wallcab spec or your offset or your crown height or anything, but whatever, it is just a number. Link to comment Share on other sites More sharing options...
RobUSMC Posted February 23, 2014 Author Share Posted February 23, 2014 https://www.dropbox.com/s/8jy08o2tfrix6vg/Humes%20Design%20-%20Drop%20Box.plan Link to comment Share on other sites More sharing options...
GeneDavis Posted February 23, 2014 Share Posted February 23, 2014 Your cabinets are not sitting on finished floor, but are on subfloor. There's your problem. Use the finished floor check-box for all cabinets. When you make the change, you will have to reset those top-box wallcabs. Link to comment Share on other sites More sharing options...
RobUSMC Posted February 24, 2014 Author Share Posted February 24, 2014 I haven't looked at it yet. I figured it was something like that she did. Thanks Link to comment Share on other sites More sharing options...
